by Osmir Investigator
PAC code does not work
Hi there!
I'm switching to another network and the PAC code I've received doesn't work though it's still valid. The new network provider insist that is not their fault.
Any lead? Anyone can help me to get this sorted out?
Thanks a lot.
Solution
Re: PAC code does not work
Hi @Osmir
Welcome to the community.
Did you manage to get sorted? Our Mobile Care team should be able to check the PAC for you.
6 REPLIES 6
by Ace Contributor
Hi @Osmir
Welcome to the EE Community,
try texting PAC to 65075  and you will get a text back
Thanks,
David.
Thanks David but I'm afraid it didn't work as I already have a PAC and it seems that service is only automated.
I tried to use the online chat but it didn't work too.
Any other suggestions but calling 150 and waiting for an half hour to get help with this issue?
Greetings.
by Ace Contributor
Hi @Osmir if you call 0800 317 720 it will put you straight through to a advisor.
Solution
Hi @Osmir
Thank you everyone!
The PAC code I had received was really defective and when I spoke to CS they provided me with a new one. All good now!
All the best for you.
Glad you got this sorted @Osmir 🙂
All the best to you as well 🙂
Have a wonderful day!
