iPhone X
    Order now
x
by Peterw1
Keeping a number from contract about to be terminated
My employer is cancelling their contact with EE, i can keep the handset so want to start a new Sim only contact with EE, can i keep my old number when the exisiting contact ends ??
by Profile closed
N/A
Solution
Re: Keeping a number from contract about to be terminated
Hello @Peterw1 it would be possible yes but the account holder (your work) would have to authorise the PAC code to be generated.
It also would depends on your works rules/terms over company numbers and whether they are kept internally or allowed to be kept by staff. Smiley Happy
by Ace Contributor
No.
You would need a PAC code and if this isn't used the contract doesn't end.
As you don't own the accountil you would not be able to obtain this code unless your employer gives it you.
Brendon (Android Expert)
Samsung Galaxy S8+ (Oreo 8.0 Beta)
by Profile closed
N/A
Solution
by Peterw1
OK thanks, will contact them and ask the question !
by Profile closed
N/A
You are welcome @Peterw1 let us know how you get on if you have the time. Smiley Happy
Recent solutions
