Highlighted
by Investigator
shared plan roam further addon
Hi, a little confused.
I have a shared plan. Sim only 40GB unlimited minutes etc.
Second user, also unlimited minutes, shared data.
On the main phone, it shows I can purchase a roam further add on,
But the second phone, doesn't have that option.
The second phone will be travelling to Canada.
Am I able to get a roam further on the second phone or not?
7 REPLIES 7
Highlighted
Re: shared plan roam further addon
@ssacoma   From the 2nd device text ROAM FURTHER to 150.  If this doesn’t add it you’ll need to call the mobile care team on 150. And to be honest I wouldn’t be surprised if it can not be added as the tariff your on is no longer available and hasn’t been for quite awhile now and it’s the older tariffs that usually have issues adding the up to date add ons and that’s why there not available any more.
Highlighted
Hi @ssacoma
Welcome to the community.
Is roaming activated for the second number?
You can check this in your My EE account.
Highlighted
by Investigator
Thanks @Chris_B . I will try the text option.
@Christopher_G I did enable the option for roaming yesterday, and I do get some roaming options for the second number:
100 global roaming texts
30 mins from anywhere
250 texts from anywhere
60 Global Roaming Minutes
120 mins from anywhere
But for the first number I also got in addition to the above
Roam Further    £ 8.33 / month recurring
Travel data pass   £4.80 - £6.00 /day
Hence the confusion. I'll see if text roaming works (fingers crossed) else it will have to be old fashioned solution of different sim.
Highlighted
by Investigator
Sadly texting didn't work. Will try customer services in case they can add.
Highlighted
Have you had a chance to have a word with them, @ssacoma?
Highlighted
by Investigator
Hi @Christopher_G ,
So I did get a chance, and they were able to add a roam further on the second line, but it would only apply to data not calls or texts. I'd have to purchse other add ons for that.
The simplest option was to migrate to a sim plan. And gift data (within the limits). Then I can add further roam on to it.
I think it should be okay like that.
Highlighted
Glad they managed to get it added for you, @ssacoma. 🙂
SIM only is definitely an option, like you said, you can share data that way and the number has its own allowances.
