by Mick_Statham Valued Contributor
Valued Contributor
Will I keep 20gb boost after upgrade
I was given a 20gb boost to my phone account last December. My upgrade date is in Feb 2020. If I upgrade with EE will I still receive the 20gb boost?
My my current plan is 4gb (24gb with the boost). As I do not use above the 4gb of the plan data per month I was thinking of a 1gb data plan to keep costs down. When I upgrade am I still eligible for a 20gb boost (making 21gb on total)?
by Ace Contributor
Solution
Re: Will I keep 20gb boost after upgrade
Hi @Mick_Statham If your still a EE broadband customer at the time of upgrade then the data boost will stay on but if you leave EE for broadband the boost will be removed immediately.
Hi @Mick_Statham
Why did you get the boost?
If it's a promotional bonus at the time on the tariff you took out, then no it will likely end when you upgrade.
Valued Contributor
Hi @Northerner i got the boost because I upgraded to fibre BB last December. As far as I can see from EE’s website this seems to be a standard extra if you have EE BB and an EE phone plan. Is that correct or am I assuming too much?
Hi @Mick_Statham
I see, if that's the boost, then yes you should retain your boost upon upgrade.
by Ace Contributor
Solution
Valued Contributor
Thank @Northerner and @David that’s a big help. I can get a better phone then on a lower data plan and still have 20gb+ of date.
Thanks folks 😊
