by Fraggle2 Investigator
Why is voicemail not working ?
I just received a voicemail but for some reason it does not seem to want to connect when I call the voicemail number.  Anyone having this problem ?
Solution
Re: Why is voicemail not working ?
OK, thanks @Shoe1
Could you try texting VM ON to 150 please?
20 REPLIES 20
by EmmzT Investigator
Yes I have the same problem. When I ring voicemail it's says I need to set a pin to access my voicemails.
I wish I got that far but mine does not even connect, 2 or 3 beeps and hangs up 😔
In fact make that 1 beep then cuts off
Sorry clicked wrong button 😞
This issue is  ot solved but wont let me undo
by vanquish
New Member
Mine isn't working either 🙁
Ok I have rebooted my phone and it seems to have solved the issue.  Not sure if its coincidence or was a network issue but maybe try that.
by Janipips
I have the same issue and calling 150 doesn't work either...that cuts off. I've rebooted the phone and it's made no difference!
by traystrackers
Voicemail asking for a pin? Cant get through to customer services on 150 either?
by sandra16
New Member
my answer phone also not working .only get 1 bleep...looks like a fault somewhere
Ok my voicemail randomly works this morning. I have not rebooted my phone although I had a system update yesterday so whether that made a difference I don't know.
Yep mine too is all good still this morning.  Must have been a temp glitchSent from my Samsung Galaxy smartphone.
Afternoon Everyone.
Thanks for coming back and letting us know your voicemail is working today.
If anyone is not able to access their voicemail after restarting the device, can you let me know.
Thanks 🙂
by mderby
Mines not working now
Hello @mderby
What happens when you call your voicemail?
Are you in the UK or roaming?
Speak soon 🙂
I am not Roaming.  Am in the UK but mine seems to be working ok as of yesterday.  Will try it again later and let you know if it has failed again.Sent from my Samsung Galaxy smartphone.
by Shoe1 Investigator
My voicemail isn’t working - I am in the uk and have rebooted the phone.
Hi @Shoe1
Welcome to the community.
Is the problem with someone leaving you a voicemail? Or calling your voicemail?
Hi, voicemail doesn’t click in at all if I am unable to answer the phone. It just rings and rings until the caller gives up.
Solution
OK, thanks @Shoe1
