by Kristen Investigator
What is cellular data connection?
What is cellular date connection? Thankyou
by Profile closed
Not applicable
Solution
Re: What is cellular data connection?
Hello @Kristen a cellular data connection is your phones internet connection over the mobile(cellular) network using 2G, 3G or 4G. 🙂
8 REPLIES 8
by Profile closed
Not applicable
Solution
Thankyou. Will I notice much difference without it do you think?
by Brilliant Contributor
@Kristen Yes you won't be able to use any internet or data unless on wifi
If you do not use the Internet, then you will not need it, really depends what you use your phone for.
It would mean you cannot use any of your apps if you do not have cellular data. You can use your apps over wifi however, and that will not cost you anything, if you have wifi or are somewhere where wifi is offered for free.
Would I ba able to connect it to my home wifi?
@Kristen Yes you sure can
Thankyou.
EE Employee
Hi @Kirsten and welcome to the Community
If you your question regarding connecting to wifi is in relation to your iPad, yes you can connect it.
Many thanks,
Lee
Recent solutions
