Highlighted
Upgrade
Just ordered an upgrade but would like a new number if possible
Highlighted
by Ace Contributor
Solution
Re: Upgrade
Hi @Michcleggy84
Welcome to the EE Community,
Once your upgrade is completed if you call 150 and ask them to change your number it can be subject to a charge of £36 but it is generally free if your experiencing nuisance calls.
Thanks,
David.
Highlighted
by Ace Contributor
Solution
Re: Upgrade
Hi @Michcleggy84
Thanks,
David.
