by Jojo00
Upgrade
I just transferred from sim only to a phone plan online, does EE know it’s an upgrade not a new plan?
Re: Upgrade
Hi there @Jojo00
Welcome to the community.
Did you select upgrade when you placed your order?
Have you received an email confirmation for the upgrade?
Speak soon.
by Jojo00
Re: Upgrade
I believe that I did select upgrade and yes I have received a confirmation of my order but how do I check it’s a confirmation for an upgrade
Re: Upgrade
Hi @Jojo00
Thanks for the quick reply.
If the email does not state an upgrade for your number, give us a quick call on 150, we will be able to check this for you 🙂
Thanks 🙂
