by Bgillham
New Member
Unlimited data plan can I gift
Hi, I’m about to upgrade and the best monthly plan for me includes unlimited data.  I currently have 2 other devices on my account and I gift them both data every month (my children).  How does this work with unlimited data or should I go for a 100gb plan?
thanks
Solution
Re: Unlimited data plan can I gift
Good Evening @Bgillham
Thanks for coming to the community 🙂
If you choose an unlimited plan you can gift up to 100GB of data or 120GB if you select a 5G smart handset plan.
This will be the first 100/120GB and any data usage used from your unlimited plan will reduce your giftable allowance.
Thanks 🙂
Solution
Thanks 🙂
