by Garry1231
New Member
Transfer Mobile Acc
I have had an account for my daughter for many years, can i transfer this to her so she becomes the account owner and bill payer?
by Ace Contributor
Solution
Re: Transfer Mobile Acc
Hi @Garry1231
Welcome to the EE Community
if you call 150 they will be able to do a change of ownership which will be subject to a credit check both you & your daughter will need to be present during the call.
Thanks,
David.
by Ace Contributor
Solution
Hi @Garry1231
Thanks,
David.
Recent solutions
