by cornishbluebird Contributor
Phone showing wrong amount of Data Allowance
Hi..
I have a plan that allows 3GB of Data Allowance, which restarts on the 20th of each month. Yet my new phone is still showing my previous plans Data Allowance of 2GB and also it has a restart date of the 6th of each month, which is the start date from when i bought the new upgrade which was from the 6th August of this year.
My phone thinks the Data is used up, and i can't use any more data now until 6th September!
Why is this doing this..
Solution
Re: Phone showing wrong amount of Data Allowance
Hi @cornishbluebird,
The 20th is your billing date with us, you can reset the data usage on the device to start from the 20th.
If you would like further information please see the Google Pixel help page here>
Thanks, Leanne.
9 REPLIES 9
by Ace Contributor
HI,
@cornishbluebird
You can find your correct data amount left clicking on this link
http://add-on.ee.co.uk
Please use your mobile data for this link not your WiFi.
Many Thanks
Thats fine, and as i said i knew this was the case. But my phone is not reflecting the fact that my data usage has restarted! So its all well and good that the online version is correct, its my phone that isn't correct.. is there something i need to do to get my phone to say the same as what i'm being told online..
Hello there @cornishbluebird
Thanks for coming here,
What device are you using?
Also what happens when you try and use the data?
Thanks, Leanne.
Hi Leanne
My phone is Google Pixel, i upgraded on the 7th August. I have just realised i can increase my GB warning, so did so to 3GB, however according to my phone i have used 2.22GB (as of now) and the dates underneath indicates this is usage used between 7th Aug - 6th Sept.
However, my details online tells me i have 2.8GB left, and the allowance restarts on the 20th September (like it used to on previous plan when it was 2GB).
Its very annoying, because i'm not sure if i'm going to run out of GB data come the 6th September!
Gareth
Thanks for coming back to me.
Usage online and the device can vary.
If you use this link  add-on.ee.co.uk.
This will show you how much data you have remaining.
Thanks, Leanne.
you have clearly not read what i have posted have you.. all you have posted is exactly what the previous so called expert had posted..
As i have stated, my phone is telling me my usage date is from the 7th Aug - 6th Sep, but my online usage date is saying its due to restart on the 20th Sep..
why is my phone giving me different usage dates..
before you go on about ee.co.uk again.. i know the one online is correct, i get that, because its the same dates my previous plan used.. i get it.. i want my phone to reflect the same, so why isn't it????
Gareth
Solution
Thanks, Leanne.
Thank you, that is very much appreciated..
Gareth
No problem @cornishbluebird
Have a great day 🙂
Recent solutions
