by FurstyFerret Contributor
Phone return timescale
Do you know roughly how long it takes to process a return under the 14-day cooling off period for buying online? Is the final balance collected via Direct Debit or is a bill sent out?
It was signed for at the returns facility on Monday but I've not heard anything since, and the My EE app still shows the new contract.
I wouldn't normally be concerned but I forgot to include anything in the package other than the phone, assuming that the barcode on the silver bag would contain the returns details.
Cheers,
Dave.
Solution
Re: Phone return timescale
It's usually done within 5 days of us receiving it back, @FurstyFerret. 🙂
Keep us posted on what happens.
Hi @FurstyFerret
Have you received a text yet to confirm that the phone has been received by us?
When did you send it back to us?
You don't need to add anything to the package, the warehouse team will scan the IMEI, which will be registered to your account.
Chris 🙂
Hi Chris,
Thanks for the information. No text, but it was only signed for on Monday so not been long.
I still have 60GB of data to chew through on a tariff that's cheaper than my old one, so they can take as long as they need. 🙂
Cheers
Dave
Solution
