by Celiaeaton
My upgrade arrived Thurs. Called to keep my number and new device still not work
Re: My upgrade arrived Thurs. Called to keep my number and new device still not
@Celiaeaton  If you upgraded your number will remain with you. if you got a new SIM card just put that in the new device if you didn’t get a SIM card put your old SIM card in the device.
by stuarttunstall Established Contributor
I upgraded from my old Note 4 on a PAYG SIM to an S8+ Contract on Wednesday, as the PAYG SIM was a multi fit one I just had to pop the smaller card out and put in my new handset... all sorted 🙂
They did send me a new, blank SIM with instructions how to activate but I did not need it.
Stuart
EE Employee
Hi @Celiaeaton and welcome to the community.
Is your old device still active or are both the phones not working?
Many thanks,
Lee
Recent solutions
