by Zack_Matthews Investigator
My contract doesn’t seem to work? I’ve tried everything, even upgrading my plan
11 REPLIES 11
Re: My contract doesn’t seem to work? I’ve tried everything, even upgrading my p
Hi @Zack_Matthews
Can you provide a bit more information.
  • Is this mobile or broadband problem?
  • If mobile are you pay monthly or PAYG?
  • Have you recently joined EE , upgraded or migrated over?
  • What device do you have and was it from EE?
@Zack_Matthews: Contract for what? In what way doesn't it work?
Need much more detail as to what your problem is.
Yes I have a monthly contract and I’m not sure if it is a mobile or broadband problem. When I connect to my WiFi I can access the internet and social media with ease however when I try to use my 4g it will show that the 4g is on and should be working but will not load anything. I previously had an iPhone 6 and it was allowing me to access the internet through 4g perfectly. However it suddenly stopped and I didn’t understand why as the contract has not ended and it is still being paid for. I have tried everything but doesn’t seem to work. I have then tried to upgrade my plan and I have got a new iPhone 7 today and it still has the same issues. Not only this my calls and texts will not work with newly added contacts?
Can't be BB if your mobile works over WiFi to your BB router.
As you only got this phone today, it might take up to 24 hours for the SIM to be recognised.
Okay, thank you
I will get back to you to see if it has worked
Hi @Zack_Matthews
Welcome to the community.
Is it any better this morning?
Does your phone show an EE connection in the top corner?
Are you able to make calls/send texts?
Look forward to hearing from you.
Sadly it still has not worked this morning.
yes it says I have stable connection and when 4g is on it also appears in the corner but doesn’t actually work?
when I add new contacts in I cannot seem to phone or call them either?
Thanks @Zack_Matthews
Please check your area on our network status checker and let us know if there are any maintenance works.
This has been going on for about 2 months now so it would be a very long maintenance break!
You don't know it's the same thing. You had a new phone yesterday. We are trying to help you with your current issue, not the past.
Thanks @Zack_Matthews.
I didn't realise it had been going on for so long.
As @XRaySpeX said, this could be an unrelated issue. It can take up to 24 hours for your new SIM to fully activate.
We recommend turning your phone off/on periodically too.
