Highlighted
Monthly
If I upgrade now on the app, will my payments still come out on the same day as my old contract
Highlighted
by Ace Contributor
Solution
Re: Monthly
Hi @Jake31
Welcome to the EE Community,
If you upgrade your phone the only thing that changes is your plan & device everything else stays the same.
Thanks,
David.
Highlighted
by Ace Contributor
Solution
Re: Monthly
Hi @Jake31
Thanks,
David.
