by Corkysworld
New Member
How much hot spot data do you get on a sim only monthly plan?
Solution
Re: How much hot spot data do you get on a sim only monthly plan?
Hi @Corkysworld
If you are in the UK then you have your full plan. If you are abroad then it's a maximum 15GB.
Solution
Hi @Corkysworld
