by constar1947 Investigator
How do i use my 20% discount Employee Voucher Code when upgrading online?
I have an employee discount voucher code, but there is nowhere to enter this code in the upgrade section when upgrading online! Even though there is a drop down, if you are applying as a new customer!
by Profile closed
Not applicable
Re: How do i use my 20% discount Employee Voucher Code when upgrading online?
Hello @constar1947 when you get to the basket/checkout stage there should be a section labeled 'Got a voucher code?' either at the very bottom just before you click proceed to checkout or just above the final total where you can enter the code before processing the order. 🙂
Nope, not seeing it..... Drop downs for BT Sport App or Apple Music, but No discount code! At the very bottom is the confirm PIN button, but cant see discount code box!
EE Employee
Hi and welcome to the Community @constar1947
So I can try and assist, please may if it is the EE Perk code that you are trying to use?
If you place your order do let me know and I can get the code applied for you.
Please do take into consideration the following:
It’s available on Pay monthly on a handset, SIM only, MBB and Tablet but there are a couple of restrictions:
  • No plans that are already on offer
  • No Max Plans with annual upgrade.
Hope this helps,
Lee
Hi, am i able to use the code in store?
EE Employee
Hi @constar1947
Unfortunately the upgrade would have to be placed online.
Many thanks,
Lee
