Highlighted
How do I upgrade to max pl
I have just arrived in Australia and will be here for the rest of 2019.
I can’t use my data for free on my current plan, but after Googling it, I see that you can use data as normal in Australia if you are on a 4GEE Max plan?
Is there a way for me to upgrade my current plan to the Max plan?
Thanks!
Highlighted
Re: How do I upgrade to max pl
@chloej21  Even with a max plan there is restrictions.  You’ll only get 2 months usage with a max plan as the tariffs are not mean for long stays abroad in fact no tariff is meant for long stays abroad.  Your best option is to get a PAYG sim from there.
Highlighted
Good Morning @chloej21.
Welcome to the community.
Wow I must say Australia is definitely on my bucket list, I would love to be able to visit The Great Barrier Reef.
@Chris_B is correct, however if you still wish for this to be changed I would recommend giving us a call on +44 (0) 7953 966 250.
Speak soon, Katie 🙂
Highlighted
You could take out the Go Further Roaming Add-on . You will need to have it for 6 months @ £10/ month.
Highlighted
@XRaySpeX Only down side to that is @chloej21 can only use it for 2 months but will still have to pay the full 6 month cost even if it’s cancelled after the 2 months.  That add on is only good if you come and go out of the UK on a regular basis.  But it’ll be cheaper than changing to a max plan for that can only be used for 2 months.
Best just to get a PAYG sim from there.
Highlighted
@Chris_B, Why? There is no 60 day stable link policy outside EU
Recent solutions
