by dylanfabian Investigator
How do I order a replacement sim
Hi I seem to have misplaced my contract sim, is there any way I can order online?
Solution
Re: How do I order a replacement sim
Hi @dylanfabian,
Welcome to the EE Community.
You can order a new SIM online but I would recommend getting in touch with customer services so we can block the SIM card you have lost.
by Ace Contributor
HI @dylanfabian
Call customer service on 150 from ee or any other provider to 07953 966 250 or you can visit any ee store to get replacement sim.
If you order on phone it will cost you £1.50 but in store its free.
Many Thanks
Thank you, I was trying to avoid calling but I’ll do it if that’s the only way , thanks for replying.
Solution
Hi @dylanfabian,
Recent solutions
