by SassaJ
Ending contract after 24 months and getting pac code
I’m hoping someone will be able to help.
My contract term in up on 14th May and I will be ending my contract then due to poor signal at home and work.
 I called 150 yesterday and, as I expected, was told to give 30 days notice to cancel on 14th May. However, when I mentioned getting my pac code, I was told that I couldn’t give 30 days notice to finish on 14/5/18 and instead would have to call on 14th May to get the pac code and give 30 days notice.
This sounds wrong to me as then I will have to pay for another month which I obviously don’t want to do!
 I’m hoping that someone will have an answer for me!
Sarah
by Profile closed
Not applicable
Solution
Re: Ending contract after 24 months and getting pac code
Basically EE are correct because as soon as they issue you a PAC, there's nothing stopping you from using it there and then foregoing your 30 days notice.  Using a PAC ends your EE contract there and then.
You will get a refund the following month for any un-used line rental though once you do use the PAC.
by Profile closed
Not applicable
Solution
by SassaJ
Thanks, that is really helpful. I was concerned by not giving the 30 days notice!
Sarah
