by kevinrob1988 Investigator
EE recycle
i was looking at putting my phone in the EE Recycle.. how do i find out which model is mine.. its the samsung galaxy s7 but theres a few different models there
Re: EE recycle
When you 1st turn the phone on the 1st splash screen should show the model no., something like "SM-G****".
Re: EE recycle
Switched it off and on a few times.. nothing shows up
Re: EE recycle
Then it'll be in the Settings, somewhere under About Device.
by Ace Contributor
Re: EE recycle
Hello @kevinrob1988 you can find your model number under Settings>About phone>Hardware info.
The S7 is the G930 and the S7 Edge is the G935.
Re: EE recycle
Hi @kevinrob1988,
Were you able to find the model number in settings>about device?
