by sadie2903
New Member
Downgrade
If I am struggling to afford my smart plan can I call up and downgrade it to a basic plan?
Solution
Re: Downgrade
No, not until you are in your upgrade window, from 45 days before end of contract term, unless you previously upgraded your plan. If you had, you may revert to your pre-upgrade plan.
If you are struggling to pay your bills, please follow What should I do if I can't pay my bill?
Solution
Re: Downgrade
