by lilyandlogan
Data reset wrong
Hi
I was wondering if someone could help. I put a block on one of my lines from using data on my ee app. I have since restored the use (one of kids was using it to stream PS4) however when I blocked it their was only 17gb of data remaining on the account till the first and now I have unblocked it it’s reser to 40gb left until the first. I don’t want to go over the allowance and then be hit by a big bill. Will this glitch rectify? When I check the usages it says 23gb of 80gb has expired and 40gb of 40gb is active. I have never had 80gb of data on any of my lines.
Thank you.
by lilyandlogan
Data usage not correct
Hi
I was wondering if someone could help. I put a block on one of my lines from using data on my ee app. I have since restored the use (one of kids was using it to stream PS4) however when I blocked it their was only 17gb of data remaining on the account till the first and now I have unblocked it it’s reser to 40gb left until the first. I don’t want to go over the allowance and then be hit by a big bill. Will this glitch rectify itself once the 17gb has been used? Anyone had similar issues? When I check the usages it says 23gb of 80gb has expired and 40gb of 40gb is active. I have never had 80gb of data on any of my lines.
Many thanks.
by Prodigious Contributor
Re: Data usage not correct
@lilyandlogan
Hi. You would be contact to EE Customer Service to discuss your issues on account.
Regads.
Re: Data reset wrong
Hi @lilyandlogan,
Welcome to the EE Community.
I'm sorry to hear your data allowance is showing incorrectly.
Please get in touch with customers services if it hasn't corrected itself.
