by Mattyabc911
Can I upgrade to a cheaper deal without paying to much charges
by Brilliant Contributor
Re: Can I upgrade to a cheaper deal without paying to much charges
If you are in your upgrade period you can downgrade to a cheaper tariff.
If you are not able to upgrade yet and still within your minimum term contract then you can't lower your tariff without cancelling the current contract.
Hi @Mattyabc911.
Welcome to the community.
Do you know if you're eligible to upgrade?
You can text UP to 150 to find out your upgrade date 🙂
Jon
