Highlighted
Can I keep my mobile number if I leave ee
Highlighted
Solution
Re: Can I keep my mobile number if I leave ee
@Trishcrane22   Yes just call customer services and request your PAC code, you then give this code to the other network and they will bring your number over from EE.
Highlighted
Solution
Highlighted
by Brilliant Contributor
Hello @Trishcrane22 ,
Welcome to the community,
Yes you can keep your number, you just need to request a PAC code, which you then give to your new supplier. Here you will find all you need to know:
https://ee.co.uk/help/help-new/getting-started-and-upgrading/keep-my-number/what-is-a-pac-code
