by Sarahlou11
New Member
Can I get a contract and keep my same number
by Ace Contributor
Solution
Re: Can I get a contract and keep my same number
If you are moving from a different network to EE, then you would need to request a PAC code from the network you are with now. The PAC code is needed for to move/migrate your current number to the new network you are moving to.
If you are with EE currently, then customer service would be able to ensure your current number is moved on to your contract. EE customer service can be reached from an EE phone on 150.
by Ace Contributor
Solution
