by julia_m
Re: How long will my prepaid SIM remain valid without a top-up?
i bought a prepaid SIM @ 7 Sept 2018 while visiting UK, next month im travelling to Vienna n then UK. can i get a pack before i travel to vienna & enjoy the roaming or i need to activate it first while in UK to a UK no?
Solution
Re: Can i get a pack before i travel to vienna from abroad?
Was last call a chargeable call? Calls from pack are not chargeable & therefore don't count. So unless that call was e.g. to outside UK you've only 7 days to top-up before it's deactivated.
Have you got a UK bank card you can top-up with? If not, you will need to wait till UK before you can top-up.
@julia_m: You should be able to if you already have enough credit on it or can top-up from wherever you are. You can do this now using your online MyEE a/c.
Which pack would you want? You may even be able to buy the pack by text msg using the right code.
When did you last make a chargeable call or text, top-up or buy a pack? Your SIM should still be active but next month it could go into hibernation unless you do 1 of these 1st.
by julia_m
i plan to buy the 5GB data ($15 data pack). this will be the first time i topup/ buy a pack.
last call is made on 12 sept 2018, & the sim is inactive ever since. if 179 days rules apply, ill have another 12 days.
Solution
