by member Established Contributor
voicemail number
I am trying to set up a voicemail PIN of my brand-new EE PAYG card from my own phone,  However, when I press key "1" (which is supposed to the "shortcut" to contact the voicemail system), I am asked to "save mailbox number first".
My question is: what is the telephone number of EE voicemail?
Solution
Re: voicemail number
If you search "Voicemail"  it will take you to EE voicemail help pages here.
Solution
