Highlighted
by Investigator
"MMS not supported on network" Note 8 - Mobile Data on - Config installed
I get "MMS not supported on network" on my Note 8
Pay as you go:
Money paid
Have not used my data limit
My mobile data setting is on
http://setup-ee.wdsglobal.com/  used and config messages installed.
Tried to send from contract 02 mobile an MMS to EE Note 8 phone that also complains about MMS not working.
Internet 4G works
Tried to send MMS from O2 contract phone to other Contract EE user. Also fail,
Coverage checker says all OK in our area
Is this some Corona thing that all Providers switched off MMS or just one cell tower?
Highlighted
Re: "MMS not supported on network" Note 8 - Mobile Data on - Config i
Hi @the_user
Try sending the MMS to yourself from your device. Does this work.
Highlighted
by Investigator
Hello Northener,
thank you for your answer.
No it does not work,
same message "MMS not supported on network"
Highlighted
Hi @the_user
Can you check your message centre number is +447958879879
Highlighted
by Investigator
Yes it is this number
I also have before send MMS messages on this phone and have not changed anything intentionally.
Highlighted
Hi @the_user.
Welcome to the community.
Do you have credit available or are you using a pay as you go pack?
Could you try restarting the phone?
Jon
Recent solutions
