by nitu_vats Investigator
pay as you go balance to be retained along with credit
Hello, i will be away from UK for next 2 months, but i have some balance in my Pay as you Go Phone. Can i park / retain this balance till i come back and use again.
Regards
Sandy
Solution
Re: pay as you go balance to be retained along with credit
@nitu_vats: You likely have a recurring Pack on your PAYG SIM, which will deplete your balance every month or week. Therefore you should text STOP PACK to 150 & start it up again when you get back.
9 REPLIES 9
by Brilliant Contributor
If you are only going away for 2 months then (and not using the phone/sim) abroad then yes this would be fine.
Only after 6 months on inactivity will the sim deactivate, then you have a further 3 months to re-activate it.
@Karen_C when this happens, does the credit forfeit at 6 months or 9 months?
thanks for response, but will my balance stay same after 2 months. how to initiate the process of retaining the credit
The balance will stay the same if the sim is not used.
You can't just 'park' it. But it will still be there after 2 months.
ok thanks, so if i dont use SIM, my balance remains the same. basically it should not be connected to any network, right. do i need to call customer care and inform them as well.
regards
Sandy
No you won't need to inform EE.
Just don't use the sim or have it connected incase it uses background data.
@BrendonH  It's 90 days then you get another 90 days to reactivated the sim after this time any credit/number  on the account will be lost if the SIM card is not activated
Thanks for clarity @Chris_B been aay from here too long, forgot some of the basics 😛
Solution
It's 179 days then you get another 90 days to reactivated the SIM - see Pay as you go Hibernation Information on EE
