Highlighted
New Member
Will the mobile phone card stop if it doesn't charge for a while?
Highlighted
Solution
Re: Will the mobile phone card stop if it doesn't charge for a while?
@JiayinHuang : By "charge" you mean top-up? If so, yes, it will.
EE PAYG SIMs are deactivated after 6 months of non-use. You then have a further 3 months to call EE to reactivate it before it is lost completely.
You need to make a chargeable action like making a chargeable call or text, topping up or buying a Pack or Add-on, not just using your mins, texts or data from your pack.
Highlighted
Solution
