by Bournetobloom
Voicemail is not working
I'm having trouble with my voicemail. I have checked all settings are on, sereral times!! Just cuts out straight away with no option to leave a message.
by Profile closed
Not applicable
Re: Voicemail is not working
Hello @Bournetobloom sorry to hear you are having problems using voicemail. What response do you get when you text the code VOICEMAIL DIVERT to 150 or call 150 and use the options anything else>phone support and content lock>voicemail? You will then need to call your voicemail on 222 from your EE phone, listen to any welcomes messages and restart your phone to complete the activation if this is your first time using or or you have not used it for a long time. 🙂
