by member Established Contributor
Unable to text/make call while overseas
Background info:
Problem: Unable to text/make call while overseas
Status: Able to receive text/call while overseas
Current Balance: GBP8
My question is: Is there a "minimum balance request" of the PAYG SIM to enable the user to text/make call while overseas?
Thanks for your help in advance. Smiley Happy
Solution
Re: Unable to text/make call while overseas
Hi @member
If you are a pay as you go customer, you should be set up to use your phone abroad.
Have you tried to tried turning the phone and off again?
If you have, then please try a manual network search.
How do I do a manual network search?
  • iPhone – Settings > Carrier > Toggle Automatic OFF
  • Android – Settings > More Networks > Mobile Networks > Network Operators > Tap OK
  • Windows – Settings > Mobile Network > Network Selection > Tap on start manual search
Let me know if this helps.
Richard
6 REPLIES 6
No, there is not, as long you have the cost of the call or text.
The fact that you are able to receive means you are good to roam. You need to phone EE to lift the International call barring.
Solution
Hi @member
Richard
@Richard_C wrote:
Hi @member
Richard
Thanks for your reply.  Smiley Happy
No problem @member
Is it working now?
Richard
@Richard_C wrote:
@No problem @member
Is it working now?
Richard
Yes, it is working now. Smiley Happy
Love it 🙂
Thanks for letting me know @member
