by Zainab98
Sim order
Hi, how can I order a free sim as i only want a sim and want to top up later
Solution
Re: Sim order
Get a free SIM, top up later would seem to fit the bill. If you don't want the pre-installed pack but just use as normal PAYG at standard rates then text STOP PACK to 150 before you top-up.
Re: Sim order
Just go into the shop at the top of the page and order sim only/PAYG here.
by Profile closed
Not applicable
Re: Sim order
You want the free PAYG SIM, which can be ordered here.
Solution
Re: Sim order
Re: Sim order
Hello there @Zainab98.
Please follow @XRaySpeX advice to make sure the pack is not activated for you!
Thanks @Profile closed @Northerner for the help 🙂
