by Sighmon55
Registering a Product on MY EE
I've just bought an PAYG EE Sim Card to go in a USB Broadband Dongle. The My EE won't let me add the number to my profile - It just keeps saying it's sending me a text message with a code in it, but the Sim Card isn't connected to a phone! So I can't see whatever code it's sending to be able to complete the process..............??
by Ace Contributor
Re: Registering a Product on MY EE
Hello @Sighmon55 connect to the device and log in here:
http://192.168.1.1
You can access the text messages through there.
If that does not work then you can put the SIM card in a phone to receive the text.
by Sighmon55
Neither solution works I'm afraid. The Link doesn't work. And I can't take the sim card out of the Dongle as I lose the Broadband - I can't access the Dongle anyway and I don't have a mobile phone
by Ace Contributor
Is this an EE 4GEE Wi-Fi device? Try here:
ee.mobilebroadband
Where is the device? Do you mean you do not physically have access to it?
MyEE doesn't work for registering PAYG MBB devices.
by Ace Contributor
@XRaySpeX yes it does EE fixed it.
