by BOC1789 Contributor
PIN reset on my top up card if I havent recorded the original
Hi ALL
Can anyone help in getting a new PIN on my EE Top Up Card when I havent recorded the original on the little selophane wrapper that came with the pack.
Thanks.
Solution
Re: PIN reset on my top up card if I havent recorded the original
That's right, @XRaySpeX
Otherwise known as a SIM PIN. 🙂
It would stop someone bypassing your device keypad lock by putting the SIM in an alternative phone.
11 REPLIES 11
by Profile closed
Not applicable
Hello @BOC1789 do you mean your PUK code for you EE PAYG SIM card?
You can locate this by logging in to your MY EE online account and navigating to MY EE>Manage device:
https://id.ee.co.uk/id/login
Hi Tim.  No I don't mean my PUK code.
I am referring to my Top Up Card. When that is delivered the 4 digit PIN and is on the selophane pack with the PUK and serial number.
I stupidly threw this selophane wrapper away.
How would I recover this 4 digit PIN?
by Profile closed
Not applicable
Hello @BOC1789 there is no 4 digit pin for electronic swipe cards you just hand it to the assistant, they swipe it, take your money and the credit is automatically loaded to the linked account without you having to do anything else (expect spend it)!
What have you been using this pin for exactly? The only top up system that requires a pin on EE is topping up by debit or credit card when calling 150. 🙂
There is a PIN on the wrapper the SIM & Top-up card came in. I'm not even sure what it's for having never used the Top-up card. It's 1111 on mine so I suppose it could be standard.
by Profile closed
Not applicable
That is the SIM pin that has nothing to do with topping up.
All new EE, T-Mobile and Orange SIM cards have a SIM pin set to 1111 by default and is written on the SIM packaging. This is used for unlocking the SIM card when the device it is in is turned on. If it has been entered incorrectly three times a PUK code is needed to unblock it.
A 4 digit top up pin it set by the user when they first top up over the phone on 150 or 07953 966 250 using a debit or credit card. This can be reset by calling customer service on the numbers previously mentioned. 🙂
Well, maybe that's the 1 the OP is after seeing he said "the original on the little selophane wrapper that came with the pack" & not 1 he had chosen on the phone. It fits the bill :)!
Hi @BOC1789
Thanks for posting again 🙂
It looks like between them @XRaySpeX and @Profile closed have got to the bottom of this.
The 4 digit PIN on the SIM is the default PIN for setting up a code for when the phone boots up. You can change this in the settings of the device.
Did you manage to get topped up?
Chris 🙂
Is that optional? I don't remember entering any PIN when I 1st started my MBB device nor do I know any way of keying nos. into an MBB.
Yes, this is optional, @XRaySpeX.
When setting up a PIN through the device settings, it will ask for the default PIN before asking you to enter and confirm a new 4 digit PIN.
After it is set up, the device will request the PIN when your device is powered on and also for turning on/off some device features.
The default PIN is given with all SIMs regardless of the device type.
OIC. It's only for setting up a PIN to unlock device if you so wish.
Solution
