by pk007
Newbee needed help on selecting a sim
what is the best plan on pay as you go which should include UK calls and texts plus international calling ? Data usage should be limited upto 2 GB.?
Many Thanks
Solution
Re: Newbee needed help on selecting a sim
@pk007 . Have a look at This
you'll be limited on what you can have because of wanting international calling.
6 REPLIES 6
Solution
by pk007
@Chris_B  - Thanks for replying. just 1 clarification , lets say I select £15 International pack and it contains 250 mins so these minutes will include both UK and international mins ?
Or is there any add-on I should be topping up.
@pk007 As stated it's for UK and the 34 countries included in the allowance
by pk007
cheers many thanks
Glad you got the help you needed @pk007
Come back to the community anytime 🙂
