by Whirlwindlass Valued Contributor
Valued Contributor
MTV Trax
I have picked up a MTV trax SIM card that says the 7gb deal ended on 02.02.17, however when I rang ee customer services they think I will still get. Do you think this is true as don't want to waste £15 topping up if so.
by Profile closed
Not applicable
Solution
Re: MTV Trax
Hello @Whirlwindlass good to hear you were still able to join just in time.
The MTV TRAX subscription auto renews along with your pack every 30days. More information on the MTV TRAX offer with EE can be found using this link. :):
http://ee.co.uk/help/accounts-billing-and-topping-up/terms-and-conditions/ee-terms-and-conditions/ee...
6 REPLIES 6
by Profile closed
Not applicable
Re: MTV Trax
Unlikely to be honest.  If the deal comes with an expiry date which has now passed it's unlikely it going to now work.
The MTV Trax order website still shows the same deal expiry date (2nd Feb 2017) and so if this deal had been extended that date should have also been extended, which it's not.
by Profile closed
Not applicable
Re: MTV Trax
Hello @Whirlwindlass you can check if the MTV TRAX pack is still on the account or if it has automatically switched back to a standard £15 everything pack by using this link from the SIMs data (not WiFi) connection:
http://add-on.ee.co.uk
Although the pack may still be there, you may not be able to take advantage of the MTV TRAX subscription itself anymore. To check text the code MTV to 150 after topping up. 🙂
Valued Contributor
Re: MTV Trax
Took the risk topped up £15 and it's all working with the MTV Trax pack and 7gb of data although it says I only have 30 days MTv Trax
by Profile closed
Not applicable
Solution
Re: MTV Trax
Valued Contributor
Re: MTV Trax
Does anyone know if I port my number across to this will this mess up the special pack?
Re: MTV Trax
It shouldn't do.
