by Brian671
New Member
I bought a £15 TOPUP voucher when I put the code in my phone it was only £5
Hi I bought a £15 TOPUP VO when put it in it only credited my phone with £5 went to shop they said I would have to contact my network provider
Solution
Re: I bought a £15 TOPUP voucher when I put the code in my phone it was only £5
@Brian671 : All EE PAYG SIMs come primed with a recurring Pack of allowances ready to bought out of your PAYG credit as soon as it is sufficient. £10 of your last top-up went to buy a £10 Pack presumably.
By texting AL to 150 it should show you the Pack you have bought with your credit & how much you have left from your allowances until its expiry date.
Text STOP PACK to 150 before you next top-up & you can use the SIM as normal PAYG at standard per-unit rates.
Solution
