by Karolinalu
Data missing
Hi, I purchased a pay as you go sim card with special offer of double data when topped up with 10£ - 4GB instead of 2GB. However, I received only 2GB. How do I get the remaining 2?
6 REPLIES 6
Re: Data missing
Hi @Karolinalu
What that offer still valid when you topped up?
You will need to call CS about the missing data.
by debs_costello Investigator
Re: Data missing
I have exact same issue and offer says valid until end of January 2019. Did you find a solution? Feeling ripped off
Re: Data missing
Re: Data missing
Well it looks like I am, I think. I've just switched from giffgaff as O2 mast has been broken for 3 months and they can't be bothered to repair it. The new sim card thingy said £10 pay as you go pack and 2Gb is crossed out and replaced with 4Gb. Maybe when I've used 2Gb it will just keep going?
Re: Data missing
It may be worth calling customer services to double check your account, @debs_costello.
They'll be able to make sure the offer is active.
Re: Data missing
Thanks I'll try that. Well, I'll ask hubby to call. I'm hard of hearing so rely on online forums etc. quite a bit. One day a company will have everything online hopefully :-). Thank you for all your help!!
Recent solutions
