by huzaifabod Contributor
DP1 failed
Hi there!
I topped up £5 with an e-voucher and now have £5 balance in my account. I texted 150 to purchase a £1 data pack using the DP1 code, I reply with YES to confirm that it will start immediately and then it keeps telling me there's a problem and try again later. I've tried for 2 days continuously and it keeps saying the same thing. Help?
by Profile closed
Not applicable
Solution
Re: DP1 failed
Hello @huzaifabod you can check the status of any packs on your account using this link from your phones data (not WiFi) connection:
http://add-on.ee.co.uk
If the pack is showing as waiting then you just need to make a call, send a text or use data after the initial free 50mb get you started data has been used up. You can also try texting the code NOW to 150 to kickstart the pack if you get an error trying to call/text or use data.
If there is no pack on the account but you have been charged for it then please call customer service on 150 from your EE phone or 07953 966 250 from any other who can access the account and check/add the pack for you. 🙂
Re: DP1 failed
Text AL to 150 to see if you've got it in case it's lying.
Re: DP1 failed
Nope it's not
by Profile closed
Not applicable
Solution
Re: DP1 failed
