by Boonnada Investigator
Change from international sim card to normal EE package using same number
In case I used an international sim card I paid £15 a month (£15 for 1 GB data, 100 UK mins, and £15 for international calls), but I would like to change to a normal package of EE (£10 for 1 GB data, 100 UK mins) using the same mobile number. Is it possible? How can I do? Many thanks in advance.
Solution
Re: Change from international sim card to normal EE package using same number
Try texting DP10 to 150 when you have £10 credit. Your SIM is just a PAYG SIM that had the International calls pack.
Solution
Is it mean I will have to pay £10 for get only  1 GB data and 100 UK mins without credits fo rinternational calls?
Yes, that's how much the £10 Data Pack costs.
You could text CALL ABROAD to 150 for the free add-on that gives you cheaper International calls & texts. EDIT Sounds like the International Pack has done that already for you.
Many thanks.
You're welcome :)! Glad I could be of assistance.
