by Leahmenzies1980
New Member
Bring my Giffgaff number to ee
How can I bring my number from giffGiff to ee
by Ace Contributor
Solution
Re: Bring my Giffgaff number to ee
Hi @Leahmenzies1980 ask for your PAC of giffgaff and give to ee.
https://ee.co.uk/help/help-new/getting-started-and-upgrading/keep-my-number/how-do-i-transfer-my-num...
Open above link you can fill the quick form or ring 150.
If you already got an ee pay as you sim you can move your on that sim or just get pay as you go temporary sim to bring your old number on that.
by Ace Contributor
Solution
