by Profile closed
Not applicable
£10 DATA Pack sim card question
Hii i have got a £10 data pack sim card and it comes with 1GB data 1000 texts and 100 minutes. but because im giving the sim card/phone to my nan i no she wont even be trying to access the internet with this phone, so i was just wondering if anything can be done about transfering it into just a minute and text sim card at all?
Thank you.
by Profile closed
Not applicable
Solution
Re: £10 DATA Pack sim card question
Hello @Profile closed she would be better off with a Talk & Text pack if that is the case. You can change the pack by calling 150, logging in to the MYEE account online or texting the pack code to 150. Here is a link containing all the packs available on EE PAYG and the codes you need to text:
http://ee.co.uk/help/my-account/pay-as-you-go/pay-as-you-go-packs-how-they-work
6 REPLIES 6
by Ace Contributor
Hello,
@Profile closed These are available pack you can change that what ever pack you want.
Many Thanks
by Profile closed
Not applicable
Solution
by Profile closed
Not applicable
Thank you so much both of you you have both been such great help.
by Ace Contributor
@Profile closed
You are welcome.
Many Thanks
by Profile closed
Not applicable
You are welcome @Profile closed hopefully see you round the community again soon. 🙂
EE Employee
Hi @8r0k3n
I'm glad you got the help and answers you needed.
Many thanks,
Lee
