by dougvcd Contributor
how to set up dvr to remote view
ok i have a dvr which worked fine on virgin media but now we with ee cant get my android phone to view remote . works on the tv and laptop if i use wifi at home it shows on phone but turn off wifi and connection faild any ideas. had 02 simcard in phone so changed it to ee still no diff
many thanks
Re: how to set up dvr to remote view
You cannot control home appliances remotely over the EE mobile network unless their manufacturer provides some sort of Cloud-based solution that monitors them continuously.
This is cuz EE mobile network uses Carrier Grade NAT (CGNAT), which means that you don't get your own public IP address but share it with other users. So you can't be uniquely id'ed on the Net by unsolicited accesses. This is unlike fixed BB.
To phone EE: The local rate landline number 0207 362 0200 or Freephone 0800 079 8586 - Option 1 for Mobiles; Option 2 for 4G WiFi; Option 3 for Home Broadband & EE TV.
ISPs: 1999: Freeserve 48K Dial-Up => 2005: Wanadoo 1 Meg BB => 2007: Orange 2 Meg BB => 2008: Orange 8 Meg LLU => 2010: Orange 16 Meg LLU => 2011: Orange 20 Meg WBC = 2014: EE 20 Meg WBC
thanks for that just had a look and there is a cloud number presume thats the port number which i have to forward
cheers
That doesn't sound like what I'm talking about. A port no. doesn't come into it.
A Cloud-based solution involves the home appliance "phoning home" regularly to its manufacturer so that no unsolicited access is required for them to know where it is. Then you login to your a/c on the manufacturer's site & it talks to the appliance on your behalf.
not sure if getting wires crossed the dvr is for cctv cams
so no way on ee to do this
cheers
Doug
Don't think so. If they provide a Cloud-based solution you would just see the DVR controls on their website and just rewind & play whatever you want to see on their site.
What model DVR is it?
by Brilliant Contributor
You should be able to download an app to see your cameras, you will not be able to see what you have recorded, but should be able to see what is going on live. I think the recordings you can only see when at home. If you had the equipment installed,  then speak to your supplier.
Ah, yes, in a Clould-based solution it could also be a mobile app as well as the website.
I have an app as well as going to D-Link's website for viewing my D-Link IP cams. You do need to register on the website 1st.
I don't see why it shouldn't also apply to DVRs.
yes i have downloaded 2 apps vmeye and vmeye+ they just wont connect
unfortunatly its a chinese dvr called DVRvision h264 digital and have lost cd that came with it so strugling to get things right plus at 70 me brain dont work as well as it did hehehe
What about vMEyeCloud? Could that be what I'm talking about?
On the phone and IPad, I have XMEye, tried the other two on the laptop with no success,to view CCTV.
yes its the phone side i am trying to get to work i have a samsung gt-7000 will try xeye
no that didnt work
thanks to all for help
ripping me hair out now cant seem to get it to work with phone and havnt got any idea what to try next except go back to virgin media.
What router is the DVR connected to?
brightbox2 from ee have just tried a foscam ip cam same problem laptop fine phone no joy even with foscam app
cheers
Sorry, I thought you were using a mobile BB router. Please ignore all I said earlier as it was about the limitations of mobile networks.
Have you port forwarded the necessary ports of these devices & tested them?
@dougvcd, with my system, I right click to get the settings up for my dvr and then guide, and then on the XMEye either click on + or search device, and it should then show up.
On mine the guide on the dvr is the welcome to the configuration where I have to click next. My dvr is specific for the cameras, not sure what you have, and I have two monitors, one in the kitchen-diner and one in the sitting room, as it is also a way of keeping an eye on my disabled daughter, as well as for the front and back of the house.
