Highlighted
New Member
Using SD card for apps on mini harrier
Hi
So little internal storage for apps.  Inserted new 32GB SD card, and still won't allow me to move or store apps on SD card.  Move to SD card option is greyed out. SD card shows in storage.  Thanks for your help.  Is there any EE helpline for such issues?
Highlighted
Re: Using SD card for apps on mini harrier
Hi @annie99
The simple answer is that Android doesn't allow all apps to be moved to SD card. These are normally their core apps, but can include apps which the device needs quick access. Android wasn't designed with SD card usage and this facility was retained by many manufacturers due to consumer demand.
If you need technical help this forum is your best bet, or call CS on 150.
Highlighted
Hi @annie99
Welcome to the community.
Are you able to move other media to the SD card? Such as pictures/videos?
