by SShaw27 Investigator
Tablet - wifi
Hi.
maybe a stupid question but if I bought/added a tablet to my current EE account would the tablet run off of the home WiFi as well as the data on the SIM?
by Brilliant Contributor
Solution
Re: Tablet - wifi
Hello @SShaw27 ,
Welcome to the community,
If you are using Wifi, then it will run off Wifi and will only use data from the SIM card, once you are not using Wifi, it will not use both at the same time, hope that makes sense.
Solution
Re: Tablet - wifi
Hello @SShaw27 ,
Re: Tablet - wifi
Thank you. I thought that might have been the case just wanted to double check 🙂
Re: Tablet - wifi
@SShaw27 , you are welcome, glad to help.
Re: Tablet - wifi
Hi there @SShaw27
Welcome to the community.
Glad you got the help you needed from @Schockwave  🙂
Have a lovely week.
Leanne 🙂
