by hoppywan
Signal Booster Box USC3331 Spec
A friend of mine has one of these and is experincing issuies ,
Can anyone tell me what the min upload/download sppeds requred to get this unit to work poroperly?
He has no info - or indeed what i'm talking about
by Legend
Legend
Re: Signal Booster Box USC3331 Spec
Hi @hoppywan
As per EE guide:
It’ll work no matter which broadband provider you use. But you'll need a minimum fixed broadband download speed of 512kbps and an upload speed of 256kbps.
EE Employee
Hi @hoppywan and welcome to the community.
Has your friend spoke to customer services and registered the device with ourselves.
Do you know if he received it directly or has bought it second hand?
Many thanks,
Lee
by hoppywan
its his and he registered it. The problem - i think is that the internet speed is far to low at 352kpbs yes
EE Employee
Hi @hoppywan
That does sound like what could be causing your friend issues.
I would get him to ring customer services just so they can run a few tests to rule out any problems.
Many thanks,
Lee
Who's his ISP? Can you get hold of his router stats? That down speed is so low that it is likely he is being banded due to a fault on his BB line which needs fixing.
Recent solutions
