Re: Samsung Galaxy smartwatch 4g
Thanks for the update @rio53
I'm happy to hear it's now working.
by rio53 Established Contributor
watch has been working as it should after all the initial hassle. Ombudsman decided in my favor and compensation was paid. It's a shame that it had to go to the ombudsman but that's EE for you.
by Carlos1966 Investigator
Hi Did you get this problem fixed>?
Hi carlos1966
I got it sorted after a long time and a replacement watch. I think the first watch must have been faulty and I think because they tried to fix the problem so many times there were too many different esims in the watch! look at my posts and you will see the problems I had. Maybe the same problem with your watch i.e that they have to clear the esims before being able to reset it? I did buy the watch from EE though so perhaps they were more keen to sort the problem out for me, even though I had to refer it to the ombudsman and got compensation (this is not your case). I did even consider cancelling and just using one with just bluetooth. All was well after the fix and working as it should.
Its all a bit of a shambles really and a scam because at the moment Im
going through a nightmare trying to get them to activate my watch with my
plan because my watch was not bought from them although it has an EE sim.
I think its out of order as if I had bought a watch from them this means
would I be able to pass it on to someone else for them to use! if I decided
to sell it? Im quite disgusted that they seem to offer no support for their
own customers despite whether the device is purchased from themselves or
not!
Regards
xxxxx xxxxxxxx
x.xxxxxxxx200@gmail.com
[mod edit: please do not post personal information on the public board. Thanks!]
