by Tiddy
Nokia 3 phone taking too long to charge phone
Why is it taking too long to charge phone
8 REPLIES 8
Re: Nokia 3 phone taking too long to charge phone
@Tiddy  Are you using the supplied charger ?
by Tiddy
Yes Same plug newer cable but correct cable
@Tiddy  How long have you had this cable for and have you used it before with no issues?
by Profile closed
Not applicable
Hi, @Tiddy,
I had a similar problem like you!
Bought a new cable for my battery charger and it still wouldn't charge quickly!
It turned out that one of the pins was loose which resulted in having to purchase another cable!
mAh8v
by Ace Contributor
Sometimes if it not the “official” product you get a slower charge.  I’ve learnt this over the years when buying unofficial cables v’s official ones.
by Profile closed
Not applicable
Hi, @Watkins07,
Good point! 😊👍
Regards
mAh8v
by Ace Contributor
@Profile closed  I only fathomed this out after trying to be a skinflint buying extra cables then getting annoyed hardly any charge was going into the phone lol.  X
by Profile closed
Not applicable
Hi, @Watkins07,
Being a skinflint, you're just like me! I only like paying £5, but sometimes you can getaway with it! 😊
Regards
mAh8v
